Atomos is excited to launch Connect, a convenient, reliable, and affordable bridge between professional 4K video capture and high frame rate UVC streaming over USB (up to 1080p60). Connect works with any HDMI device including the entire Atomos range. Simple to use, it has universal support from popular streaming platforms and at only $79USD is an affordable way for gamers, vloggers and education facilities to up their streaming game using the professional Atomos monitor-recorder ecosystem.
Convert, Connect, Stream
Connect bridges the Atomos world of professional recording and monitoring with popular streaming platforms such as YouTube, Twitch and OBS. Use your Atomos device for professional shot setup and recording and use Connect to simply convert the HDMI output to USB on the go for streaming on your Mac or PC. Connect accepts up to 4Kp30 video and is capable of up to 1080p60 output over USB – incredible streaming quality for the US$79 price point.
Plug and go like a pro
With a slim 0.5-inch profile, Connect is sleek enough to sit directly off your laptop or computer. No drivers are required and no power supply either, meaning it really is a simple matter of connecting your Atomos or HDMI device to your Mac or PC to start producing like a pro.
Shogun7 Connect – tame multicamera streaming
The Atomos Shogun7 allows you to monitor and record up to four 1080p60 streams simultaneously and then cue and switch in real-time with a simple touch of the screen. Additionally, the Shogun7 is able to accept asynchronous feeds (sources don’t need to be locked), allowing the user to use more affordable cameras for multi camera production. Adding in Connect, lets you output the switched feed for live streaming on your Mac or PC. This makes the Shogun7 Connect package one of the easiest and most affordable options for professional switching.
Transforms your Camera to a Pro Webcam
Even without an Atomos monitor-recorder, Connect transforms your HDMI camera to a powerful professional webcam. No drivers required, plug in Connect and go live instantly.
The Atomos Connect is available immediately for $79/€79 from the global authorised Atomos dealer network.
Or if you just want a straight 1080 HD capture, try this ... https://www.amazon.co.uk/dp/B08DR3ZR6V
I have one and they work great into OBS Studio. Even the small £8 dongles are supposed to be fine.
I wonder if this capture device will be reliable enough to compete with the $300 industry-standard Magewell USB Capture Gen2, or if this is any different than those $15-20 capture cards that also claim 1080p60 capture.
Previously I made the mistake of buying an $80 generic capture card and learned to pay for quality instead.
The more interesting question for me is which USB standard version has UVC (USB Video Class). A capture card, this is not! It piggybacks on the USB chipset of the laptop. USB 3.1 Gen2 I'm sure has it, but what about Gen1? USB 3.0 is likely useless.
Capitalism :-)
