Zhong Yi UHD 4K+ B4 to m43 mft 2X Extentder Adapter
    • Made for B4 2/3 ” lenses
    • 8 elements in 5 groups
    • 2x magnification
    • Corresponding sensor size (image circle) - 21mm
    • Φ66 x total length 76 x height 98mm
    • includes tripod mount
    • 440g
    UHD 4K + is a mount conversion extender adapter for mounting a 2 / 3-inch B4 mount lens developed by Zhong Yi Optics on a Micro Four Thirds standard camcorder. Equipped with a high-performance optical lens that doubles the focal length, the lens configuration is 8 elements in 5 groups, and by adopting a lens design optimized for the Micro Four Thirds image sensor, it supports up to 4K resolution (* used) If the B4 lens to be used is compatible with 4K). The lens barrel is made of aluminum alloy, and the mount on the camera side is made of highly durable stainless steel used for cinema lenses. With a tripod mount that can be attached to and detached from an Arca-Swiss compatible standard tripod or pan head.
    http://stkb.co.jp/info/?p=14627
  • 2 Replies sorted by
  • Nice (if it works well) but over £800 and most B4 lenses have extenders built-in to them anyway. Never heard of Zhongyi so not sure if its "MetaBones" quality or "eBay" quality. For that price I would hope it would be very good indeed.
  • So the adapter does not correct for single sensor camera? It's just an extender and that's all?
