Canon C200 Camera
  • 84 Replies sorted by
  • @MikeLinn how do you know it's C200?
    (How do we know you are not a bot who does nothing but linking video clips?)
  • @peaceonearth
    Do not worry so much, it was really shot on C200.
  • how do you know? And have you more info about settings?
  • New v1.0.3.1.00 firmware
    1. XF-AVC format recording has been added1 2* 3* 4.
    2. Retrieval of lens metadata, such as focal length, is now supported during XF-AVC recording.
    3. Hybrid Log Gamma HDR ITU-R BT.2100 output has been added.
    4. Sensitivity adjustment has been added for the LM-V1 LCD Monitor.
    5. LPCM 24-bit audio recording has been added when recording in the Cinema RAW Light format*5.
    6. 4X magnification has been added.
    7. A PsF output function from SDI and HDMI has been added during progressive internal recording.
    8. A digital tele-converter function has been added (1.5x, 3.0x, and 6.0x).
    9. Auto IRIS support has been added for the following lenses:\ -- EF-S 35mm f/2.8 Macro IS STM\ -- EF 85mm f/1.4L IS USM
    10. Peripheral illumination/chromatic aberration correction has been added for the following lenses:\ -- EF 70-300mm f/4-5.6 IS II USM\ -- EF 16-35mm f/2.8L III USM\ -- EF-S 18-55mm f/4-5.6 IS STM\ -- EF-S 35mm f/2.8 Macro IS STM\ -- EF 85mm f/1.4L IS USM
    11. The reproducibility of bright areas has been enhanced when the gamma setting is from Normal 1 to 4.
    12. Browser remote setting options are retained after switching off the camera.
    https://www.usa.canon.com/internet/portal/us/home/support/details/cameras/cinema-eos/eos-c200?subtab=downloads-firmware
  • Upgrading from mirrorless
  • Service advisory
    We have determined that a recording error may occur with the EOS C200 / C200B. The details of the phenomenon and support plan are described below.
    Preparations are underway to incorporate improvements/revisions for the phenomenon into the latest Firmware for the EOS C200 / C200B. Once this Firmware is available for download, we will make an announcement on our website.
    We sincerely apologize for the inconvenience caused to customers, and we ask for your ongoing patience.
    Phenomena
    Image quality degradation, such as color misalignment or edge distortion, may occur in the recorded footage when using the following combination of settings:
    • Recording format XF-AVC
    • Frame rate 59.94i / 50.00i
    • 1920×1080 resolution
    Workaround
    Users should use a configuration that does not include the settings listed above, although we acknowledge that this may not be possible for all users.
    Note: This Phenomenon only affects internally recorded footage. Output signals from the output terminals are not affected.
    Affected Products
    • EOS C200 / C200B Digital Cinema Cameras equipped with Firmware Version 1.0.3.1.00 are affected.
    Support
    Firmware Version 1.0.3.1.00 has been removed from Canon's Web site. The new Firmware is scheduled to be released mid-June 2018.
    If you have not already done so, please register the EOS C200/C200B. By registering, we will be able to notify you via email about future announcements.
    This information is for residents of the United States and its five territories only. If you do not reside in the USA or its five territories, please contact the Canon Customer Support Center in your region.
  • Firmware Version 1.0.4.1.00
    Fixes image quality degradation, such as color misalignment or edge distortion, may occur in the recorded footage when using the following combination of settings:
    • recording format XF-AVC
    • frame rate 59.94i / 50.00i
    Optimizes the Black Gamma compensation when Normal 1 to Normal 4 is set for Gamma in the Custom Picture settings.
    Optimizes color accuracy in areas of high brightness when Normal 1 to Normal 4 is set for Gamma in the Custom Picture settings.
  • Hey guys! I dont know if you have seen this but Adorama has a limited offer to all EOS C200 lovers. Please see attached pic. The offer includes "free expedited shipping" too.
    EOS C200 8.85MP EF Mount 4K UHD Digital Cinema Camera with Prime Lens Bundle
    Canon EOS C200 + Prime Lens Kit
    Price: $10,499.00 Regular Price: $12400.00
    2212 x 1324 - 668K
  • New firmware
    Firmware Version 1.0.5.1.00 incorporates the following enhancements and fixes:
    1. A Continuous Recording function has been added allowing for nonstop recording.*1
    2. Peripheral illumination / chromatic aberration correction has been added for the following lenses:
      • EF Cinema Lens: CN-E20mm T1.5 L F
      • EF Lens: EF 70-200mm f/4L IS II USM
    3. For LUTs that can be applied to output footage, official support for the ITU-R BT.2100 standard and ITU-R BT.2408 report have been added for the following terminals:.\
      • SDI terminal\
      • HDMI OUT terminal\ Changes have been made so that the [HDR: PQ] and [HDR: HLG] base luminance corresponds to Diffuse White (100%) being 203nits*2.
    4. Support for the [Reset] function that resets the clip number when the reel number is set, has been added.
    5. When using an assignable button, the White Balance setting will be maintained after the power has been turned off.
    6. Fixes a phenomenon that occurs on cameras with firmware versions 1.0.3.1.00 to 1.0.4.1.00 in which resolution appears to be reduced in SD card recordings and in external outputs when shooting with specific menu settings*3.
    • 1 When using the continuous recording function, only MP4 format/1920x1080 resolution is possible.
    • 2 The HLG output is the brightness in the case of displaying on a 1000nits monitor.
    • 3 Specific menu settings:
      • When [Resolution/Color Sampling] is set to [3840x2160 YCC420 8 bit].
      • When [Resolution/Color Sampling] is set to [1920x1080 YCC420 8 bit], and [Slow Motion Recording] is activated.
      • When [Resolution/Color Sampling] is set to [1920x1080 YCC420 8 bit], and the digital tele-converter and EF-S lens correction are activated.
    https://www.usa.canon.com/internet/portal/us/home/support/product-advisories/detail/firmware%20notice%20eos%20c200%20-%20c200b%20firmware%20version%201.0.5.1.00/
  • Crazy.
    I just discovered that C200 has HDMI and SDI (but only one of each) however.... ONLY ONE WILL WORK AT A TIME!!
    What a big kick in the face for any professional production. (as if the lack of timecode wasn't bad enough)
  • What a big kick in the face for any professional production. (as if the lack of timecode wasn't bad enough)
    What is so bad with "lack of timecode". Just get one of plenty of solutions for this, they are cheap.
