                  Preview
http://jacobjamesphotography.co.uk/g80-perfect-hybrid/
Samples
https://www.dpreview.com/news/9319412290/panasonic-lumix-dmc-g85-sample-gallery
                  Preorders
Looks great! so, does it record 4K 4:2:2 internally? no mention for that.
In the Jacob James article it says it has it.
Ominously little mention of the HDMI out signal for external monitors and recorders, as far as I can see
B&H photo first look
OK, so in the above video, the Panasonic rep says you CAN use external monitors/recorders AND record/monitor internally at the same time. HOORAY!!
BUT, he says that it only records 4:2:0 internally. BOO!!
I think it was some misunderstanding, and it is HDMI that is 422 8bit, as with FZ2000.
Bhphoto video says it records 8bit 4:2:0 internally.
I'm getting confused: I thought the FZ2000 had 10-bit HDMI out?
Yep, but also 422 8-bit mode. It'll be all more clear in coming days.
Yeah, no worries. We all know it's too much to ask for a huge multinational to actually publish accurate and detailed specifications on new products…
5 axis in-body stabilization... am I understanding correctly that means it'll work to stabilize all my manual focus legacy lenses...?
Yep.
anyone know, what means ibis v2? It's improved since gx85 or it's other way(may be crop with gyro info) ? Really interesting, want some test of IBIS
It's explained in the B&H video
This rep is saying 8bit 422
It works in video or just photo? I think, that gx85 already have synhro camera IBIS and IS in lens And what lens are supported? If thats link is correct (http://shop.panasonic.com/dual-is/dual-is-lenses?srule=newest&sz=24&start=0) its sad that new 42.5 f1.7 with superb is in not supported
Log?
No log, no dice.
Video shot on g80. Have to say it looks a bit over-sharp/saturated and "videocam-like" for my tastes. I'd dial things down a notch or two
29 minute time limit.........unless.......
https://www.dpreview.com/news/3393180242/hands-on-with-the-panasonic-lumix-dmc-g85
There is no headphone socket unfortunately, but now we can stream to an HDMI monitor while recording 4:2:2 to the memory card.
