Hi, a noob question...
Is it possible mounting the camera at 90° on the attachment plate?
Would be possible obtaining a lateral movement, something like a slider? I mean maintaining the camera horizontal while moving the monopod on his legs from left to right while pointing the subject.
I hope you understand what I'm meaning :)
Bye
@longjohn silver. No you can't mount a camera at 90degrees, it's a two way head. You can't really get a slider horizonal movement. You can, with the legs on the ground, lean the monopod above the ball joint to the side and get a horizontal movement that way. It will be a little diagonal movement really, since your height will drop as well depending on the angle.
The movement will not be slider smooth. With practice you can make it pretty smooth.
