Lytro inside (from FCC report)
Btw this guys still keep talking and talking and not presenting actual product to masses. Months after months. Looking at photos above we can see pretty standard cheap compact base. Nothing fancy.
I thought they got aliens technology!!!
The image sensor board (in image: Lytro4-5) looks very Elphel... ;-)
There are plenty of papers on the internet which describe the concept and fwiw, the "original" was implemented using a modded Canon DLSR. The basic idea is you capture a light field which is in essence an array of images constructed using a coded pinhole/aperture array and from that you can reconstruct a final image using some algorithm. Stanford University have an uber camera array which basically accomplishes the same thing. Its pretty interesting stuff. It also allows you to "see through" objects ;) Search for computational photography and you'll get a load of results.
The lytro sellings has started..
