Heh guys, I'm hack noob shooting a wedding soon and i need a patch that i can span with, so i went with crb 44/32 settings. Did i little span test of shooting myself on the tread mill (Shooting 1080 24L, with the Panny 20 .17 (Manual focus), Sandisk Class 10 32g), to see if everything is fine. Only issue with this test, is that the wind shut the fucking door where all the light was coming for. So its under exposed. If you look at the picture, below my knees, you'll see some crap. This is a the start of the second 4gig file, when its on the time line (Pre CS5) Is this the codec freaking out because its to dark, i'm i worrying about nothing or does this happen in 24L 32mbps when you join spanned files together? Don't have time to do another test to see... Cheers
                  weird things can happen between the spanned files if your editing software is not made for that because the previous keyframe will be in the previous file and the NLE doesn't know that they are basically one continuous file. It has no way of knowing. What i do when i'm managing imports manually is use the unix command cat (i'm on mac) on my spanned files to literally concatenate them into one big file. Then the NLE should be fine with it (ie Final Cut Express no longer has glitches). There should be a similar command in windows command prompt i think.
As far as high bitrate spanning, try the SpanMyBitchUp (sp?) setting found in the GH2 settings vault thread. Should span on most class 10 SD cards on 24H. (caution: Will often not span on 24H 80% speed)
Also, spanning often depends on complexity of the image. sometimes it'll span once if there is little motion in the frame at that time, then die on the 2nd file if there is more motion or more noise then.
But if you really really need it to just work and don't have time to test, save yourself the headache and use stock firmware then experiment later what you have time. Shooting trees blowing in the wind out the window for hours on end with an AC adapter is my method for determining if it will reliably span.
