Description:
The Rhino Slider equips you to film 48" of cinematic glory. The system is based on 6 rollers filled with 12 sealed ball bearings mounted to a hard-anodized aluminum carriage. There is so little friction you can use gravity to move your shots. Locking all-terrain legs come standard with non-marking custom molded rubber feet that will grip to anything.
Features*:
• 2 mounting screws are included: Standard 3/8-16 for your ball or fluid head and a 1/4-20 for mounting your iPhone or GoPro
• Dual locking friction brakes (not shown) keep the carriage in place when you're moving from shot to shot or traveling
• The entire system dissassembles with only 4 tool-less fasteners
• 3/8-16 & 1/4-20 threads on both ends of the slider for mounting to tripods
• 3/8-16 thread on both ends for vertical mounting
• Replaceable feet let you use suction cups to mount to a car or window
Specs:
• 48" Stainless Steel Tubular rails
• 6061-T6 Hard Anodized (Type III) Aluminum
• Weight: ~5lbs
• Stainless Steel hardware
• $400
*This is for the base model. There are also carbon fiber "Pro" versions available for a higher price.
Some video reviews:
