Fujifilm X-T4, High Bitrate 4K, APS-C king of the mountain
    • 26mp APS-C sensor with IBIS (up to 6.5 stops)
    • compared to T3 1/3 of an inch thicker, and about 5-6oz heavier
    • Video - DCI/UHD 4K at 60 fps, Full HD at 240 fps
      • 4096 x 2160 @ 60p / 200 Mbps, MOV, H.265, Linear PCM
      • 4096 x 2160 @ 50p / 200 Mbps, MOV, H.265, Linear PCM
      • 4096 x 2160 @ 30p / 400 Mbps, MOV, H.265, Linear PCM
      • 4096 x 2160 @ 25p / 400 Mbps, MOV, H.265, Linear PCM
      • 4096 x 2160 @ 24p / 400 Mbps, MOV, H.265, Linear PCM
      • 4096 x 2160 @ 23.98p / 400 Mbps, MOV, H.265, Linear PCM
      • 3840 x 2160 @ 60p / 200 Mbps, MOV, H.265, Linear PCM
      • 3840 x 2160 @ 50p / 200 Mbps, MOV, H.265, Linear PCM
      • 3840 x 2160 @ 30p / 200 Mbps, MOV, H.265, Linear PCM
      • 3840 x 2160 @ 25p / 200 Mbps, MOV, H.265, Linear PCM
      • 3840 x 2160 @ 24p / 200 Mbps, MOV, H.265, Linear PCM
      • 3840 x 2160 @ 23.98p / 200 Mbps, MOV, H.265, Linear PCM
      • 1920 x 1080 @ 240p / 200 Mbps, MOV, H.265, Linear PCM
      • 1920 x 1080 @ 120p / 200 Mbps, MOV, H.265, Linear PCM
      • 1920 x 1080 @ 60p / 200 Mbps, MOV, H.265, Linear PCM
      • 1920 x 1080 @ 50p / 200 Mbps, MOV, H.265, Linear PCM
      • 1920 x 1080 @ 30p / 200 Mbps, MOV, H.265, Linear PCM
      • 1920 x 1080 @ 25p / 200 Mbps, MOV, H.265, Linear PCM
      • 1920 x 1080 @ 24p / 200 Mbps, MOV, H.265, Linear PCM
      • 1920 x 1080 @ 23.98p / 200 Mbps, MOV, H.265, Linear PCM
    • Anamorphic ratios available in video
    • Fully articulated screen, 1.62mdots
    • Lack high res photo modes using pixel-shift, can come with new firmware.
    • Dual SD-Card slot
    • NP-W325 battery rated at 2200mAh 16Wh
    • USB Power Delivery for charging, up to 30W
    • 607 g
    • 135 x 93 x 84 mm
    • $1699 at
    741 x 586 - 58K
  • 56 Replies sorted by
  • Sounds very good. If they give a 12 bit external usb-c ssd option like on zcam and sigma, it will be wonderful.
  • This is exciting because you got to think they must have improved the DR , IQ and rolling shutter in this release, the XT3 was an amazing value for video, this could possibly finally replace my ursa for B cam
  • Sounds good, with 10-bit internal this is gonna be a big winner.
  • Fujifilm X-T4 coming and will be announced Feb 26th
  • New info is that camera in fact won't be available till fall of 2020.
    Paper announcement only.
  • Camera won't record 6K as previously rumored.
  • Hopefully the 10-bit internal info is still correct.
    I'm very curious to see what the dynamic range is compared to the S1/S1H and the BMPCC6K. I really like Fuji color. Even the X100v looks like a great little travel/street camera. I'm due to upgrade from a GH5 and both the X-T4/X100v might be the right fit.
  • 10 but internal is a given, since X-T3 has this, and it was a major selling point. 6k external would be nice, 12 bit external would be great. 12 bit internal would make me wet my pants.
  • Correction, XT-3 is 4:2:0 10-bit versus GH5/S1/SH1 4:2:2 10-bit.
    4:2:2 plus unlimited recording time and decent dynamic range would make this an easy purchase for me.
    685 x 517 - 70K
    800 x 582 - 83K
  • Bad move not using the LCD hinge from the XT-100 ou copied the Panasonic S1H. Both tilt and flip, please both still and video shooters.
  • I dont think IBIS is important. A monopod can do a much better job. And a OIS lens is fine for handheld situations when you cannot use the monopod.
  • But when you can't use a monopod, IBIS works better than OIS for video, at least in my experience.
  • According to Fuji Rumors, the XT-4 price will be $1700.
  • OIS isnt enough in many situations. For instance it cannot correct rolling movements. A monopod doesn't do much when you need to move the camera (boom/truck/dolly etc). Works fine for panning and tilting. And does absolutely nothing when you're shooting in places that won't allow it.
  • Haha Fast charging battery, that's about 5 years overdue. Anyone see any word on the time limit?
  • Specs
    Image sensor
    23.5mm x15.6mm (APS-C) X-Trans CMOS 4 with primary color filter. 26.1 millions pixels.
    Storage media
    SDXC memory card (-512GB) UHS-I / UHS-II / Video Speed Class V90
    Movie
    MOV (MPEG-4 AVC/H.264, HEVC/H.265, Audio: Linear PCM / Stereo sound 24bit / 48KHz sampling), MP4 (MPEG-4 AVC/H.264, Audio: AAC)
    Movie Recording and Compression
    • All Intra/Long-GOP
    • DCI4K/4K 29.97p/25p/24p/23.98p 400Mbps Full HD (2048 x1080)/ Full HD (1920 x1080) 59.94p/50p/29.97p/25p/24p/23.98p 200Mbps
    Movie File Size/Frame Rate/Rec. Time
    • DCI 4K (4096 x2160) 59.94p/50p/29.97p/25p/24p/23.98p 400Mbps/200Mbps/100Mbps 59.94p/50p: up to approx. 20min. 29.97p/25p/24p/23.98p: up to approx. 30min
    • 4K (3840 x2160) 59.94p/50p/29.97p/25p/24p/23.98p 400Mbps/200Mbps/100Mbps 59.94p/50p: up to approx. 20min. 29.97p/25p/24p/23.98p: up to approx. 30min\
    • Full HD (2048 x1080) 59.94p/50p/29.97p/25p/24p/23.98p 200Mbps/100Mbps/50Mbps up to approx. 30min.
    • Full HD (1920 x1080) 59.94p/50p/29.97p/25p/24p/23.98p 200Mbps/100Mbps/50Mbps up to approx. 30min.
    • Full HD (1920 x1080) High speed rec. 240p / 200p 200Mbps(recording) up to approx. 3min. 120p / 100p 200Mbps(recording) up to approx. 6min.
    Image Stabilizer Mechanism
    Image sensor shift mechanism with 5-axis compensation
    Image Stabilizer Compensation Effect
    Maximum 6.5 stops (based on CIPA standard. Pitch/yaw shake only. With XF35mmF1.4 R lens mounted.)
    Digital Image Stabilizer
    Yes (movie mode only)
    IS Mode Boost for movie mode only
    Face and Eye detection AF
    Movie Shutter
    • FHD: 1/8000sec. to 1/4sec.
    • DCI4K/4K: 1/8000sec. to 1/24sec. (depends on the frame rate)
    Continous Shooting
    • Approx. 30fps [Only electronic shutter, 1.25 x Crop ] (JPEG: 60 frames Lossless compressed RAW / Compressed RAW: 35 frames Uncompressed RAW: 33 frames)\
    • Approx. 20fps [Only electronic shutter, 1.25 x Crop ] (JPEG: 114 frames Lossless compressed RAW / Compressed RAW: 37 frames Uncompressed RAW: 34 frames)\
    • Approx. 10fps [Only electronic shutter, 1.25 x Crop ] (JPEG: 500 frames Lossless compressed RAW / Compressed RAW: 48 frames Uncompressed RAW: 39 frames)
    • Approx. 20fps [Only electronic shutter ] (JPEG: 79 frames Lossless compressed RAW / Compressed RAW: 36 frames Uncompressed RAW: 34 frames)\
    • Approx. 15fps (JPEG: 110 frames Lossless compressed RAW / Compressed RAW: 38 frames Uncompressed RAW: 35 frames)
    • Approx. 10fps (JPEG: 164 frames Lossless compressed RAW / Compressed RAW: 44 frames Uncompressed RAW: 37 frames)
    • Approx. 8fps (JPEG: 200 frames Lossless compressed RAW / Compressed RAW: 49 frames Uncompressed RAW: 39 frames)
    Viewfinder
    • 0.5 inch approx. 3.69 millions dots OLED Color Viewfinder\
    • Coverage of viewing area vs. capturing area: approx. 100%\
    • Eyepoint: approx. 23mm (from the eyepiece lens)\
    • Diopter adjustment: -4-+2m-1 (lockable)\
    • Magnification: 0.75 x with 50mm lens (35mm equivalent) at infinity and diopter set to -1m-1\
    • Diagonal angle of view: approx. 38 Degree (Horizontal angle of view: approx. 30 Degree )\
    • Built-in eye sensor
    LCD monitor
    • 3.0 inch, aspect ratio 3:2, approx. 1.62 millions dots touch screen color LCD monitor (approx. 100% coverage)
    Wireless Transmitter Standard
    IEEE802.11b/g/n (standard wireless protocol)
    Bluetooth Standard
    Bluetooth Ver 4.2 (Bluetooth low energy)
    Terminal
    • Digital interface: USB Type-C (USB3.2 Gen1x1)
    • HDMI output: HDMI micro connector (Type D)
    • Other: 3.5mm, stereo mini connector (Microphone) / 2.5mm, Remote Release Connector, Hot shoe, Synchronized terminal
    Power supply
    NP-W235 Li-ion battery (included)
    Battery life for still images
    Approx. 600 frames (Economy Mode), approx. 500 frames (Normal Mode) When XF35mmF1.4 R is set.
    Actual battery life of movie capture Face detection is set to OFF
    • [4K] approx. 85min. (29.97p)
    • [Full HD] approx. 95min. (59.94p)
    Continuance battery life
    • Face detection is set to OFF
    • [4K] approx. 110min. (29.97p)\
    • [Full HD] approx. 130min. (59.94p) (movie capture)
    Battery
    Li-ion battery NP-W235
    Dimensions (D x W x H)
    63.8 x 134.6 x 92.8 mm
    Weight
    Approx. 607g (including battery and SD memory card) Approx. 526g (excluding battery and SD memory card)
  • So there's still a 30-minute record limit, that's a bummer.
    Vitaliy, any news on whether they implemented 4:2:2 10-bit?
  • @Isaac_B
    Seems like LSI is same old one.
  • Photos
    800 x 535 - 65K
    800 x 625 - 48K
    800 x 710 - 63K
  • seems like snake oil here )
  • @sammy
    As one man told me this week - industry stopped.
    Sony still keep moving using money from their smartphone income, but they will start taking huge hit starting March (as they got most of Chinese orders and their cartel partner Samsung is not hit yet).
    Japanese nice idea pay their top managers bonuses each year by selling and destroying semiconductor business now is showing results.
  • 30 minute limit=stupid
  • @DrDave
    Actually not. Looks stupid only from our side of the fence.
    Small money saved for top managers - nice.
    No need to work and modify code ensuring work with larger files - nice.
