70-200mm F2.8 S PRO L Mount Panasonic Lens
    • 22 elements in 17 groups, 1 aspherical + 3 ED + 3 UED elements
    • 11 diaphragm blades
    • OIS - up to 7 stops with Dual IS 2 compatible bodies
    • 0.95m min focusing distance
    • Linear AF Motor
    • Internal focusing
    • Weather sealed
    • 94mm x 209mm
    • 82mm filters
    • Comes with lens hood and tripod collar
    • 1570 g
    • $2599 price, available in January
    800 x 590 - 57K
    800 x 531 - 39K
    750 x 545 - 33K
  • 11 Replies sorted by
  • PR
    Panasonic is proud to introduce two new interchangeable lenses based on the L-Mount system for the LUMIX S Series Full-frame Digital Single Lens Mirrorless Cameras. Designed for professional use, the LUMIX S Series offers uncompromising photographic expression with its high-quality cameras and lenses.
    The LUMIX S PRO 70-200mm F2.8 O.I.S. (S-E70200) is a large-aperture telephoto zoom lens that boasts high descriptive performance across the entire zoom range. The LUMIX S PRO 16-35mm F4 (S-R1635) is a versatile wide zoom lens that provides high resolution images and a beautiful bokeh despite its compact, light-weight profile. Both high-performing LUMIX S PRO lenses achieve LEICA's stringent standards.
    LUMIX S PRO/S Lens Lineup as of November 2019
    • LUMIX S PRO 50mm F1.4 (S-X50)
    • [NEW] LUMIX S PRO 16-35mm F4 (S-R1635)
    • LUMIX S PRO 24-70mm F2.8 (S-E2470)
    • LUMIX S 24-105mm F4 MACRO O.I.S. (S-R24105)
    • [NEW] LUMIX S PRO 70-200mm F2.8 O.I.S. (S-E70200)
    • LUMIX S PRO 70-200mm F4 O.I.S. (S-R70200)
    In addition to Panasonic's existing portfolio of first-class lenses for the LUMIX S series family of cameras, the company is committed to designing and developing 11 or more lenses with the emphasis on the "LUMIX S PRO" class by March 2021. Currently, more than 46 interchangeable L-Mount lenses are available or will be available from Panasonic, Leica Camera AG and Sigma, opening up a virtually limitless spectrum of new creative possibilities.
    Designed and developed for professional field shooting, the LUMIX S PRO 70-200mm F2.8 O.I.S. (S-E70200) uses 2 UED (Ultra Extra-low Dispersion) lenses, 3 ED (Extra-low Dispersion) lenses and optimum alignment comprising 22 elements in 17 groups, effectively suppressing both axial chromatic aberration and chromatic aberration of magnification. Astigmatism is also corrected with an aspherical lens, achieving high resolving performance. Adoption of a double focus system suppresses fluctuation of aberration even at close distances, which results in high descriptive performance from the center to the corners over the entire zoom range despite its large aperture.
    Covering from 70mm to 200mm, the use of a Teleconverter allows a maximum 280mm (1.4x, with DMW-STC14) and 400mm (2x, with DMW-STC20) super telephoto shooting1, with maximum 480 fps focus control for high-speed, high-precision auto focus. The O.I.S. (Optical Image Stabilizer) in the lens complies with the camera's Body I.S. and the 5-Axis Dual I.S. 22 makes it possible to use a 7-stop slower shutter speed*3. Adoption of a focus clutch mechanism enables instant AF/MF switching and accurate manual focusing.
    The constant F2.8 large aperture provides smooth defocus gradation from the focus peak to the neighboring area of the image to achieve a beautiful bokeh effect as well as a rich perspective. The LUMIX S PRO 70-200mm F2.8 O.I.S. also excels in video recording performance with a mechanism that suppresses focus breathing, which was a fatal problem in all interchangeable lenses designed for still image photography.
    The rugged, dust/splash-resistant design withstands use under harsh conditions even at 10 degrees below zero for high mobility. The filter size is 82 mm, with an 11-blade circular aperture diaphragm.
    Both lenses will be at retail in January. The LUMIX S PRO 16-35mm F4 will available for $1,499 and the LUMIX S PRO 70-200mm F2.8 is $2,599.
