NITZE Gh5/Gh5s Camera Cage
    The Nitze PHT01 formfitting cage is designed for the Panasonic GH5 / GH5S and is made of anodized aluminum alloy for lightweight and durability.
    The cage prevents damage to the camera plus it gives plenty of 1/4"-20 & 3/8"-16 accessory mounting holes and a HDMI cable clamp. All the ports on the camera are unobstructed by the cage. The NITZE cage is made of anodized aluminum alloy for lightweight and durability. This setup costs $88.
    For $149, Nitze includes the PA14 Top Handle with cold shoe and 15mm rod clamp. There are multiple 1/4’’-20 and 3/8’’-16 threaded holes and ARRI locating holes to attach other external accessories.
    The handle helps capture dynamic low angle footage with proper balance and maintains comfort during long shooting.
    The $239 GH5 Cage Kit includes also the Nitze PB05 Base Plate with Built-in ARCA QR holder witch makes you able to quickly remove or mount the camera cage by putting an included ARCA QR plate on the bottom of the cage.
    Also there are 2 x 15mm 100mm aluminum alloy Rods and 2 x 15 mm 200mm aluminum alloy Rods for mounting rod accessories as a matte box or follow focus.
    This is a nice cage from Nitze. Has a cold shoe on the cage offset, most cages don't.
    800 x 746 - 72K
    800 x 580 - 83K
    800 x 749 - 86K
    594 x 800 - 74K
    635 x 800 - 76K
