45mm F2.8 Sigma small lens
    Rumored specs
    • Designed specially for FF mirrorless cameras
    • Small and light
    • Pancake like construction
    • AF, but not too fast
    • Really sharp
    • Affordable
    594 x 500 - 46K
  • 6 Replies sorted by
  • PR
    An enjoyable prime lens your camera can hardly part with - Admirably balanced performance and size for full-frame mirrorless cameras from our Contemporary line
    1. Newly developed high-performance lens series for full-frame mirrorless cameras
    2. Beautiful bokeh and rendering that can be enjoyed in every scene
    3. High-speed and highly accurate AF enabled by the stepping motor
    4. High build quality and outstanding operability
    Launch: July, 2019
    SRP: £549.99 (including VAT)
    Lens Hood (LH577-01) supplied
    Available AF mount: L-Mount, Sony E-mount
    Embody the Contemporary line’s concept of “Pursuing optimum balance”
    Achieve the best balance of a lens suited for everyday use
    Designed for combination with relatively small full-frame mirrorless cameras, this standard lens pursues easy operability as a regular prime lens by balancing its easy-to-carry size and high optical performance, thereby embodying the Contemporary line’s development concept of “pursuing optimum balance," and becoming the perfect first lens in the lineup dedicated for full-frame mirrorless cameras.
    Key features
    With mirrorless cameras emerging at an accelerated pace, expectations towards lenses suited for high-performance full-frame mirrorless cameras are growing. Unfortunately, many photographers may feel that they have little choices for mirrorless lens systems in terms of performance, size, extensive lineup, and due to the burden of having to use multiple systems. SIGMA has thus developed and proposes this new full-frame mirrorless lens series as the optimal solution to this challenge.
    SIGMA will develop interchangeable lenses with unprecedented specifications and performance by designs that benefit from the short flange focal length feature of mirrorless cameras while retaining the concepts of “Contemporary,” “Art,” and “Sports.” We will announce three models as the first lenses from this series.
    45mm F2.8 DG DN | Contemporary
    Compact size is realized while maintaining high image quality and is compatible with full-frame mirrorless cameras. This prime lens refines the concept of the Contemporary line.
    35mm F1.2 DG DN | Art
    The world’s first* 35mm F1.2 as L-Mount and Sony E-mount lens for full-frame mirrorless system. The high image quality of the Art line that pursues ultimate performance is realized by F1.2 maximum aperture.
    14-24mm F2.8 DG DN | Art
    Large-diameter, ultra-wide-angle zoom lens for full-frame mirrorless cameras.
    While pursuing the ultimate image quality of the Art line, the size is reduced thanks to the exclusive design for mirrorless cameras.
    With the SIGMA 45mm F2.8 DG DN | Contemporary, bokeh expressions are especially featured. Spherical aberration has been controlled to ensure not only the large bokeh in the front and rear of the subject but also the rear bokeh near the area in focus create a gradient to a soft blur. This lens softens the periphery of blurred images suppressing the double-line bokeh etc. and enhances the three-dimensional impression of the subject with the smooth expressions in the foreground and the background. In addition, its minimum focusing distance of 24cm makes it possible to enjoy shooting snapshots and tabletop photos taking advantage of the angle of view. The design gives consideration to vignetting to achieve beautiful round bokeh and subdue swirly bokeh in the whole bokeh effects.
    While this lens produces smooth bokeh effects of which one could say as “classical expression” when the aperture is wide open, it also realizes modern sharp rendering when it is stopped down. It is reassuring to hold this lens as the regular lens for everyday use.
    The lens is capable of smooth, quiet and high-speed AF made possible by a stepping motor, as well as supports Face/Eye Detection AF and video AF. The design gives consideration to MF operations, and a ring of appropriate torque provides good operability.
    Because this lens is intended for everyday use, particular attention has been given to build quality and operability. The bayonet hood feels comfortable when removing and attaching, and the lens barrel incorporating metal material as the main part achieves improved durability. Furthermore, thanks to the aperture ring with the right click feeling, comfortable operability during various shooting styles is ensured.
    Other features
    • Mount with dust- and splash-proof structure
    • Full-time manual mode
    • Available Mount Conversion Service
    • Designed to minimize flare and ghosting
    • Evaluation with SIGMA’s own MTF measuring system: A1
    • 7-blade rounded diaphragm
    • High-precision, rugged brass bayonet mount
    • “Made in Japan” craftsmanship
  • Nice looking lens. Can't work out if it's focus-by-wire as the blurb states "Full Manual" operation possible. And 500+ Eud is not a cheap lens. Will have bad distortion corrected by software internally.
