14-140mm F3.5-5.6 II LUMIX G VARIO ASPH. POWER O.I.S Lens
    • 14 elements in 12 groups (2 ED and 2 aspherical lenses)
    • Dustproof and drip proof
    • The appearance is almost the same as H-FS14140-KA
    • Filter diameter: 58 mm
    • 7 diaphragm blades
    • Min focus distance is 30cm
    • Stepper motor AF
    • Size: φ 67 mm × about 75 mm
    • Weight: 265g
    • $599.99.
    • Will be available in May 2019
    800 x 612 - 63K
  • 2 Replies sorted by
  • PR
    Panasonic announced today that it has updated the LUMIX G telephoto zoom lens based on the Micro Four Thirds system standard. In addition to the versatile zoom range from wide-angle to telephoto, the new LUMIX G VARIO 14-140mm / F3.5-5.6 II ASPH. / POWER O.I.S. (H-FSA14140) features a splash/dust-resistant* construction for heavy field use yet retains its stylishly compact profile remains lightweight.
    The Practical zoom range of 14-140mm (35mm camera equivalent: 28-280mm) suits a wide range of shooting situations. It can capture dynamic landscapes, bring subjects up close, or shoot impressive portraits with beautifully defocused backgrounds.
    Comprised of 14 elements in 12 groups, the lens system features three aspherical lenses and two ED (Extra-low Dispersion) lenses to achieve dramatic downsizing of the powerful 10x optical zoom lens, while minimizing distortion and chromatic aberration.
    The POWER O.I.S. (Optical Image Stabilizer) effectively compensates for not only small, fast movements, but also large, slow movements, making it easy to shoot super clear shots even in low-lit situations at nighttime or indoors.
    Incorporating an inner focus drive system and stepping motor, the new LUMIX G VARIO 14-140mm / F3.5-5.6 II ASPH. / POWER O.I.S. is capable of smooth, silent operation to work with the camera’s high-speed, high-precision contrast AF system for both photo and video recording. It is also compatible with the sensor drive at max.240 fps to take maximum advantage of cameras with high-speed AF.
    The LUMIX G VARIO 14-140mm / F3.5-5.6 II ASPH. / POWER O.I.S. (H-FSA14140) is built with a highly reliable metal mount, and uses multi-coated lens elements that minimize ghosts and flare. Seven blades give the aperture a rounded shape that produces an attractively smooth defocus effect in out-of-focus areas when shooting at larger aperture settings.
    The LUMIX G VARIO 14-140mm will be available at valued channel partners in May for $599.99.
    611 x 363 - 18K
