Think Tank Stand Manager 52 Rolling Case
    • Crush resistant ABS twin-wall provides end-to-end reinforcement
    • Oversized, shock-absorbing wheels roll smoothly and hold up under the toughest conditions
    • 52" of internal height for those extra-large modifiers or gel rolls
    • Multiple tie-down straps secure your stands on the inside of the bag
    • Expands and contracts to fit your gear
    • Four exterior handles for easier lifting and loading
    • Built tough with highest quality materials (#10 YKK RC Fuse zippers, 1680D ballistic nylon and ABS Twinwall reinforcement) and proven high-quality * construction
    • Large interior pocket for umbrellas or small modifiers
    • Roomy interior for a few sandbags
    • Rear skid rails and tall wheel housings allow you to load and unload from a vehicle with ease
    • Reinforced bottom panel holds up to heavy stand abuse
    • Clam shell opening gives unencumbered access to gear
    • Lockable zippers (lock not included)
    • User replaceable wheels and hardware
    • Exterior Dimensions: 12.5” W x 54” H x 4.5–8” D (31.8 x 137.1 x 11.4–20.3 cm) Weight: 12.1 lbs. (5.5 kg)
    • $279 https://www.thinktankphoto.com/collections/rolling-cases-manager-series/products/stand-manager-52
    800 x 679 - 70K
