Lilliput A5 aka Neway CT500HO Little 5" Monitor
    • FullHD 400 cdm² IPS panel
    • 1000:1 contrast
    • HDMI Video Input with 4K support
    • HDMI Video Output with 4K support
    • Input Voltage - 7-24V
    • Power Consumption ≤ 12W
    • 80 mm x 129.8 mm x 23.6mm
    • 118g
    • Very affordable at $145 - https://www.amazon.com/dp/B07D9WL9ZF/
    707 x 727 - 64K
    734 x 570 - 38K
  • 32 Replies sorted by
  • Yes! Another small monitor on the market. As I've always felt 7"+ monitors are overly large for an operator to use (large monitors are better off for an AC or director).
  • @IronFilm
    We'll make review with all measurement and all soon.
  • can this power the camera too?
  • More photos of Neway version of this monitor
    782 x 526 - 51K
    731 x 513 - 34K
    757 x 406 - 20K
    749 x 534 - 34K
    740 x 320 - 31K
    701 x 629 - 56K
    737 x 449 - 45K
  • I just received mine today. Ordered Lilliput version from Amazon. While there is a lot to like, there is a lot to dislike.
    First the positives:
    1. This thing is crazy lightweight and compact. Exactly the size I am looking for.
    2. The screen is very sharp, colors look good, and brightness is good.
    3. Boot-up time is about 5 seconds - faster than a lot of field monitors.
    4. Three 1/4" mounting points seem secure so far despite plastic build quality.
    5. Lot of options in menu to customize monitor.
    6. Battery meter is a nice feature IF you can get the battery option to work (see below).
    7. Brightness (not backlight), contrast, saturation, tint, sharpness, and volume all accessible with arrow keys w/o going into menu. (press one arrow key, brightness setting comes up, then use menu button to toggle which setting you are adjusting.
    Now the negatives:
    1. Battery connection with NP batteries is no good. I am going to return mine and see if another copy has the same issues - maybe get the Neway version. The prongs themselves are nice and snug inside the battery, though any simple movement of the monitor causes it to reset when a battery is attached. I have tried 4 different brands of NP-style batteries as well as all 3 sizes (NP-F550/750/970). These batteries all work great in other devices and are fully charged, so I know it's not the batteries. It seems to have bad wiring inside.
    2. Pixel-to-Pixel mode doesn't work, even though the monitor reports to receive 3840x2160 signal. There is option for zoom (aside from pixel-to-pixel mode), which takes several clicks through menu to get to (unless you set one and only Fn button to be "scan" but it really looks like a digital zoom of a down-scaled image - so not that useful as the image becomes pixelated, especially at 4x, but even at 2x - again the signal is a 4k/UHD feed.
    3. Only one Fn button. I knew this before buying it, and am willing to overlook this.
    4. Only way to set backlight setting is in menu. This is different from the brightness setting. Would be way more useful to have direct control to backlight setting with arrow keys without menu.
    5. Sunshade is a joke. Velcro glued into inside of monitor frame is poorly done and was already partially peeled away when I opened the box. Velco glued to sun shade also partially peeled off before use. Sunshade is also so flimsy and comes warped that it's impossible to mount it without it blocking part of the screen. Really wish they didn't mount the velcro and just included it as an option, as it's so poorly mounted, yet will probably leave a gooey mess if one tries to remove it.
    6. When a battery or power cable is attached, the front LED indicator stays red, so I would guess that even if you powered off, it may still partially drain a battery.
    7. Power button is right next to exit button, so very easy to turn monitor off when adjusting various settings or just closing menu screen.
    8. Ships with a Mini-HDMI cable - not micro or full size - but the middle-sized one, which very few devices still use. Would much rather no cable or a full size ship.
    9. When switching into DCI (17:9) 4k (4096x2160), it sometimes appear properly scanned for a split second, then stretches the image vertically to fit 16:9 screen. There is option in menu to set aspect ratio to 1.85:1 which is not the correct 1.90:1 of DCI 4k, but should be close enough for most.
    I do understand this monitor is about as cheap as they come, so my expectations were never that high. I would be willing to deal with all the negatives, if at very least I could get it to work for more than a few seconds with a battery. Don't have any LP (Canon) style batteries here to test LP-batt connectors, but I need this to work with NP (Sony) style batteries, or it's a no go for me. There is a micro-USB port under the battery compartment, so I am thinking they can probably fix the pixel-to-pixel mode via a firmware update. And maybe even add the backlight setting to the arrow keys.
    @Vitaliy_Kiselev - where did you find info about the Neway version of this? Cannot seem to find that online anywhere.
  • @sam_rides_a_mtb
    Thanks for detailed feedback.
    Actually we just get A5 into US lab, so can check all bad or good points.
    Also I make sure that Lilliput management will get info about negatives.
  • Great, thank you VK! Good to know that they will receive this feedback. Initiated the return on my unit and hoping to get a new one with the battery connection working properly. Will post updates when that happens.
  • @sam_rides_a_mtb
    Btw, make macro photos of connector.
    With some connectors you can make them better just using very thin screwdriver or such.
  • You can see the prongs make very good connection with the contacts on the battery. Issue seems to be internal that wires going to connectors are loose or shorting.
    4032 x 3024 - 1M
    4032 x 3024 - 972K
    4032 x 3024 - 935K
  • Having internal wiring that is loose is surprising! Usually it is the external connections, even if you hold it in firmly with your hands (or a rubberband) does the monitor still reset when you jiggle it?
  • I have been in contact with the seller and they are exchanging it for me. Will report back when I have the new one. @IronFilm, even if I hold the battery snug, it has issues. Touching the monitor with literally a feather touch causes the issues. Sometimes it just flickers, but most of the time, it just reboots. The connectors are very snug in the batteries. The fit is definitely better than some other devices I have that use NP batteries.
  • In our US lab
    800 x 964 - 99K
  • @Vitaliy_Kiselev did Alan test yet with NP style batteries? Just packaged mine up to send back. Hoping replacement works properly, as I really love the size and weight of this thing, not to mention the color and DR is pretty good. That's also a different ballhead than I received, though guessing that may not be the included one.
    Another note, you need to turn volume to 0 on monitor if you don't have headphones plugged in, otherwise sound from camera/mics comes through the speaker and feeds back.
  • I received my refund, but held off on getting a replacement just yet. Any updates from the PV US Lab?
  • $140 US Free Shipping
    Damn it, happens literally days after I purchased mine! Ah well
  • Amazon Link in 1st post doesn't work. This new link.
    short link: http://a.co/gKEyyIi
    Linkdelight
    $149 Free Shipping
    sometimes they have coupons off new purchases, or current coupon : 6% off orders $300 or more : LD006, 7% off -$500 or more: LD007
    https://www.linkdelight.com/P0048011-Lilliput-A5-5-Camera-Top-Broadcast-Monitor-4K-HDMI-1920x1080-for-DSLR.html
  • @jleo
    Thanks, fixed link.
  • Just finished my a weekend of shooting with the Liliput A5 for the first time, and I really liked it! Was a nice screen (in fact the B cam would often be using it for himself! Rather than for its purpose: to be pointed at me, so I could keep an eye on the B Cam shots), seemed to be battery efficient (I think? I wasn't doing battery management though, that was B Cam AC's job) while being super small and lightweight.
    For its price (only US$149!) I think this was an awesome bargain buy.
  • Monitor panel macro
    It is IPS panel.
    800 x 620 - 97K
  • Delay at 1080p60
    Quite typical for such monitors
    800 x 486 - 45K
  • Not so bad for sub US$150!
