60mm F2 Yongnuo YN Lens
    Specifications
    • 10 lenses in 9 groups
    • 7 aperture blades
    • F16 min aperture
    • 0,23m min focus distance
    • 67mm filters
    • 76×115mm dize
    • 586g
    0.234m macro mode, the magnification ratio is up to 1:1
    The nearest focus distance can reach about 0.234m, and the magnification ratio is up to 1:1. Shooting in macro mode and infinity mode both can achieve good image quality, which is suitable for shooting in macro, portrait, landscape and other scenes.
    Supports USB-free Firmware Upgrade
    Firmware of the lens can be upgraded through camera instead of using USB port, which not only meets the requirements of firmware upgrade and appearance design, but also avoids the incompatibility problems caused by different computer operating systems.(Note: this function needs to be supported by camera)
    F2 Large Aperture
    F2 bright and large aperture, easy to create beautiful bokeh effect and highlight the subject.
    Built-in electromagnetic aperture, supports automatic exposure shooting
    Built-in electromagnetic aperture, supports M/Av/Tv/P/B and other shooting modes, and can effectively improve the accuracy and durability of the aperture control.
    High precision manual focus, supports focus prompt
    Adopts high precision focusing structure design, supports half-press shutter manual focus prompt.
    Glass Lenses, Multi-coated
    The whole series products are formed by glass lenses, adopting multi-coated technology, which effectively improve light transmittance and inhibit the ghost shadow and glare in photographing.
    Seven Aperture Blades
    The aperture blades are up to 7 pieces, which allows you to shoot the circular defocused spots, appropriately stopping down can also achieve the 14 astral effect.
    Metal Bayonet, Outstanding durability
    Adopts chrome high precision metal bayonet, which fits the camera body perfectly, and the bayonet is wear and corrosion resistant, durable in use.
    Equipped with focus distance indicator
    Equipped with focus distance indicator, it is convenient for you to estimate the distance of the subject.
    Gold Plating Technology
    Adopts gold plating metal contacts, effectively improves the signal conductivity and corrosion resistance.
    545 x 567 - 28K
    627 x 551 - 43K
    417 x 396 - 26K
  • 1 Reply sorted by
