About the DJI Phantom 4 Pro v2.0:
The new Phantom 4 Pro v2.0 features an OcuSync HD transmission system, which supports automatic dual-frequency band swiping and connects to DJI Goggles wirelessly. Like the Phantom 4 Pro and Advanced, the Phantom Pro v.20 is equipped with a 1-inch 20mp sensor capable of shooting 4K/60fps video and Burst Mode stills at 14fps. Plus, its FlightAutonomy system includes dual rear vision sensors and infrared sensing systems for a total of 5 directions of obstacle sensing and 4 directions of obstacle avoidance.
Camera with 1" 20mp Sensor:
The onboard camera has been redesigned to us a 1" 20mp CMOS sensor. A custom engineered lens made up of eight elements is arranged in seven groups, it is the first DJO camera to use a mechanical shutter, eliminating rolling shutter distortion which can occur when taking images of fast moving subjects or when flying at high speed. In effect, it is as powerful as many traditional ground cameras. More powerful video processing supports H.246 4K videos at 60fps or H.265 4K at 30fps, both with a 100mpbs bitrate. Advanced sensors and processors ensure everything is captured with more image detail and the image data needed for advanced post-production.
1-Inch 20-Megapixel CMOS Sensor:
Sensor size is more important to image quality that the number of pixels because a larger sensor captures more information in every pixel, improving dynamic range, signal-to-noise ration, and low light performance. The 1" 20mp CMOS sensor in the Phantom 4 Pro v.20 is almost four times the size of the Phantom 4's 1/2.3" sensor. It uses larger pixels and has a maximum ISO of 12800 as well as increase contrast. It is good enough for images to be used immediately, while also capturing enough detail for advanced post-processing.
Production Optimized 4K:
An enhanced video processing system allows video to be capture in cinema and production optimized DCI 4L/60fps at a bitrate of 100Mbps, enabling you to get high resolution slow motion shots. The Phantom 4 Pro v2. also supports H.265 video codec (Maximum resolution 4K/30fps). For a given bitrate, H.265 doubles the amount of image processing as H.264, resulting in significantly enhances image quality. Record in the high dynamic range D-log mode to make the most of this image data for color grading.
High Resolution Lens:
The resolution and contrast of a lens is critical to image quality, because only a quality lens capture sharp, vivid photos at high resolutions. The brand new Phantom 4 Pro v2.0 camera has an aerial optimized f/2.8 wide-angle lens with a 24mm equivalent focal length. It features eight elements -- 2 aspherical -- arranged in seven groups that fit into a smaller, more compact frame. Its images are consistently detailed with low distortion and low dispersion, ensuring that photos and videos are sharp and vivid. For the first even with DJO camera, MTF results have been made public, so people can get a better understanding of lens performance.
US PR
DJI Introduces V2.0 Edition Of The Phantom 4 Pro
With DJI OcuSync Transmission, 60% Propeller Noise Reduction And Simultaneous Wireless Connectivity For An Enriched FPV Experience
Fans of the iconic DJI Phantom drone can look forward to the release of the Phantom 4 Pro V2.0 (P4P V2.0), the latest variation of the Phantom 4 Pro. Packed with the powerful features of the P4P, the P4P V2.0 uses DJI's OcuSync transmission technology for high-resolution and low-latency digital video transmission and improves the flight experience by reducing propeller noise by up to 60%. Users who utilize the first-person-view experience for work or for play, can directly connect the P4P V2.0 with their DJI Goggles for an immersive FPV flying experience.
With 30 minutes of flight time, 7 km transmission range^[1]^, 5-directional obstacle sensing system and 1'' CMOS Sensor with 4k@60p video recording capabilities, the P4P V2.0 is a drone fit for prosumers and professionals who need a reliable and powerful imaging solution that can cater to diverse filming needs and mapping operations.
Retaining its iconic white airframe, the P4P V2.0 also has a Phantom 4 Pro+ V2.0 version, which comes with a 5.5-inch, 1080p resolution screen built-in to the remote controller for operators who often fly outdoors under direct sunlight.
Price and Availability
The Phantom 4 Pro V2.0 is now available for purchase at store.dji.com, the four DJI Flagship Stores and authorized dealers worldwide. Its US retail price of USD$1,499 includes the aircraft, battery, remote controller, four pairs of propellers, battery charger, power cable, gimbal clamp, Micro USB cable, Micro SD Card and a carrying case. The Phantom 4 Pro+ V2.0 retails at USD$1,799 and includes all P4P V2.0 accessories, but with the 5.5-inch monitor built into the remote controller. For availability and pricing in local currency, visit store.dji.com.
DJI is excited to announce that the Phantom 4 Pro V2.0 will again be available for purchase on January 6, 2020. This popular and versatile drone had been temporarily out of stock because of a shortage of parts from a supplier. DJI sets high standards for the extremely advanced components in our products, which require advanced lead time and technical precision to manufacture. We apologize for any inconvenience this may have caused our customers, and we thank them for their patience as we ensure the Phantom 4 Pro V2.0 will continue to meet their high expectations.
