G7 denoise presets and profiles for NeatVideo 4, 4K and FHD
  • NeatVideo 4 denoise presets and profiles for Panasonic Lumix G7, for 4K and Full HD.
    Conservative amount of denoise to avoid plastic look and keep image texture after denoise.
    Camera settings:
    Standard
    Sharpness +1 (also works for sharpness 0)
    Noise reduction -5
    Two versions:
    Without shadow/highlight curves
    With shadow/highlight curves, S+3/H-3 (the maximum amount before image gets ugly) (can be used also for S+2/H-2)
    Download in posts below:
  • 8 Replies sorted by
  • 1080p without S/H
    g7_fhd.zip
    819K
  • 1080p with S/H
    g7_fhd_sh.zip
    817K
  • 4k without S/H
    g7_4k_0200-0400-0800.zip
    1M
    g7_4k_1600-3200-6400.zip
    1M
  • 4k with S/H
    g7_4k_sh_0200-0400-0800.zip
    778K
    g7_4k_sh_1600-3200-6400.zip
    1M
  • 1080p Extended Tele Conversion mode without S/H
    g7_fhd_etc.zip
    1M
  • 1080p Extended Tele Conversion mode with S/H
    g7_fhd_etc_sh.zip
    986K
  • New versions with less amount of denoise in chroma channels in an attempt to avoid flat color surfaces in low light and shadow areas.
    g7_4k_0200-0800.zip
    1M
    g7_4k_1600-6400.zip
    1M
    g7_4k_sh.zip
    2M
    g7_fhd.zip
    628K
    g7_fhd_sh.zip
    625K
    g7_fhd_etc_sh.zip
    792K
    g7_fhd_etc.zip
    839K
  • Fine tuned profiles and presets using new footage from denoise target, more calibrated exposure and more accurate settings. Using 1/3 iso increments from 200 up to 2000, the maximum useful iso in G7. Now 4k ISO 1600 looks like ISO 100.
    Camera settings: Standard, sharpness +1, noise reduction -5, saturation 0, contrast 0.
    SH versions use Shadow +2 / Highlight -2 in camera. ETC = extended tele conversion mode.
    Also using less amount of denoise in chroma channels to avoid flat color surfaces in low light and shadow areas.
    If you want to use higher isos, 2500 and above, I recomend use camera noise reduction in "0". Instead of using these isos it is better to add light.
    g7_4k_0200-0400.zip
    1M
    g7_4k_1250_2000.zip
    1M
    g7_4k_0500-1000.zip
    2M
    g7_4k_sh_0200-0400.zip
    1M
    g7_4k_sh_0500-1000.zip
    2M
    g7_4k_sh_1250-2000.zip
    1M
    g7_fhd.zip
    1M
    g7_fhd_etc.zip
    2M
    g7_fhd_etc_sh.zip
    2M
    g7_fhd_sh.zip
    2M
