18-55mm T2.9 Cine Fujinon lens
    PR
    The Optical Devices Division of FUJIFILM has unveiled the MK Series of cinema lenses for E-mount cameras, which boast advanced optical performance, ultra-compact and lightweight design, as well as superb cost performance. The first in this series to be introduced, the FUJINON MK18-55mm T2.9, is a standard zoom with an 18-55mm focal length. It will be available in early March at a list price of $3,799. The entire “MK” series is designed with the ‘emerging’ cinematographer in mind, whether shooting a live event, online programming, documentary, corporate video, wedding, independent or short film production.
    The next in the series, the FUJINON MK50-135mm T2.9*1, will be available this summer. With a combined focal length range of 18mm-135mm in the Super 35mm format, together the first two “MK” lenses cover the most frequently used range utilized by emerging cinematographers. The series offers fast lenses with T2.9 speed across the entire zoom range, enabling a shallow depth-of-field.
    “The rapid growth in popularity of content produced by emerging cinematographers has expanded the use of cinema and digital photographic cameras,” said Tom Fletcher, Director of Sales, Optical Devices Division of FUJIFILM. “And the heightened need for programming has, in turn, boosted demand for high-performance cinema lenses, which are ideal to achieve a shallow depth-of-field and a beautiful bokeh. However, since they are typically large, heavy and expensive, those involved in online and other lower cost productions often opt for interchangeable lenses for digital cameras, which have been more affordable and mobile. The problem is that interchangeable lenses for digital cameras are designed primarily for shooting stills, and therefore prone to focus shift and optical axis shift while zooming.”
    The “MK” lenses are designed to maintain consistent color temperature with all FUJINON cinema lenses, which simplifies color grading2. The series also inherits the FUJINON cine lenses’ advanced edge-to-edge optical performance and low distortion3, while boasting compact and lightweight design as well as outstanding cost/performance. The MK18-55 and MK50-135mm weigh in at a light 980 grams/2.16 lbs with front diameters of 85mm and lengths of 206mm. The MK18-55mm’s minimum object distance (MOD) is .85 meters/2.78 feet, while the MK 50-135mm’s MOD is 1.2m/3.93 feet.
    “Many independent shooters use DSLR lenses, which aren’t designed for moving images. Still lenses breathe considerably, and they have no adjustable manual iris,” said Fletcher. “Our MK’s have a seamless manual iris, zero breathing, no ramping or zoom shift, and 200-degree focus rotation. They maintain focus completely throughout the zoom range while covering Super 35mm sensors.”
    In addition to their lightweight and compact build, the “MK” lenses are designed from the ground up with the operator in mind. Only one matte box and one filter size are needed between the lenses. Time-saving features include a macro function that allows for a broader range of close-up shooting, and gears for the three rings are positioned in the exact same place, which eliminates the need to re-position accessories when switching lenses.
    The lenses each contain a Flange Focal Distance adjustment function*4 to achieve optimal camera and lens matching. The short flange focal distance contributes to the lenses’ compact size and lightweight. Distances are listed in feet and meters.
    The iris supports seamless adjustment that is free of clicking. This enables precise exposure adjustment without any sound from clicking between T-stops.
    The lenses also feature three rings for manual and independent adjustment of focus, zoom, and iris (aperture), with the gear pitch*5 of 0.8M (module). The focus ring can rotate fully up to 200 degrees to facilitate precise focusing.
    The “MK” lenses are compatible with E-mount cameras with the Super 35mm/ APS-C sensor.
    X Mount versions of the MK lenses (with focal lengths of 18-55mm and 50-135mm) used in the FUJIFILM X Series line of digital cameras (with APS-C sensors) are being developed for launch by the end of this year. Information about the X Mount lenses will be provided as soon as more details are confirmed.
    713 x 417 - 34K
  • 14 Replies sorted by
  • X mount later this year ? My little finger tells me, Fuji will bring a dedicated cinema camera later this year ala FS5/FS7 with X mount ! Who wanna bet ?
  • May be. Cost of such camera is only 20-25% more compared to photo body and margins are much higher even considering that Fuji (and new Sony models) has highest margins in the industry now.
  • @Faudel, that's exactly what I said too when I read that they were bringing it to X mount. I hope they pull out all the stops for such a camera.
  • Example where it is clear that only $3900 lens can shoot it
    http://www.photogearnews.com/sample-images-fujinon-18-55mm-t-2-9-lens/
    800 x 542 - 110K
  • We have received feedback from a few customers that the iris blades did not move correctly when the iris ring was rotated.
    As a result of our internal investigation, we found the potential risk that the MK18-55mm lens produced in a partial production lot, in rare cases, would cause the above problem.
    Therefore, our technical staff will inspect your MK18-55mm lens with the following mentioned serial numbers free of charge. For more information, please contact your shop or dealer where you purchased the MK18-55mm lens to make arrangements to have your MK18-55mm lens sent for inspection.
    We do apologize to any of our loyal customers that may be affected by this inconvenience. Please rest assured of Fujifilm’s absolute commitment to quality and service excellence.
    Serial number - from 75A00001 to 75A00354
  • Things to know
    Test
