Benro Sliders and Cranes
    MoveUp4 Jib
    • Folding Design – The MoveUp4 Travel Jib folds up into a small, portable package making this ideal for filmmakers who need travel friendly gear. Its compact design pairs nicely with smaller tripods and lightweight cameras, therefore reducing the overall amount of equipment required to enhance your production value.
    • Vertical reach – With a vertical reach of just over 6 feet, the MoveUp4 Travel Jib can achieve sweeping shots for that cinematic look.
    • Accessory Mounting – Threaded mounting points allow you to attach a monitor arm to view your shot live while operating from the back of the jib.
    • Carrying Case – Each MoveUp4 Travel Jib comes with its own carrying case for easy transportation and protection.
    MoveOver4 Slider
    • 4 Bearing Carriage - The carriage operates using 4 bearings that run along two stainless steel embedded rods providing smooth movement for your shot.
    • Center mountable - Center mounting the slider is made easy using the included cheese plate.
    • Supports up to 8.8 lb (4 kg) - Supports the weight of HDSLRs and small video cameras as well as a flat base head.
    • Vertical mounting - The threaded end blocks (1/4"-20 & 3/8"-16) make it easy to mount your slider vertically, which helps provide more diverse movements.
      • Articulating rubber feet - Easily adjust and level your slider with the articulating rubber feet.
    MoveOver8 Slider
    • Carbon Fiber Rails - Ideal for strength and lightweight support, the MoveOver8 includes two 100% 18mm carbon fiber rails.
    • 4 Bearing Carriage - The carriage operates using 4 quiet operation bearings that run along two carbon fiber rods providing smooth movement for your shot.
    • Supports up to 17.6 lb (8 kg) - Supports the weight of HDSLRs and HD video cameras as well as a flat base head.
    • Stand Adapters - Each end block includes a 3/8"-16 female adapter that when removed becomes a 5/8" port for mounting on C-stands and light stands.
    • All-Terrain Legs - Conquer any terrain and level your slider with the articulating all-terrain legs with adjustable rubber feet.
    • Carrying Case - Deluxe carrying case included for easy transport and protection.
    MoveOver12 Slider
    • Carbon Fiber Rails - Ideal for strength and lightweight support, the MoveOver12 includes two 100% 22mm carbon fiber rails.
    • Flywheel with Belt Drive - Precise control flywheel with rubber track belt drive.
    • Supports up to 26.5 lb (12 kg) - Supports the weight of HDSLRs and heavier HD video cameras as well as a flat base head.
    • Available in 600mm and 900mm lengths.
    646 x 610 - 40K
    636 x 597 - 31K
