This test took a surprising amount of time to put together. I have a thought that the GH2 does not like to be shaken. On the mount the GH2 often reported card failures. On a tripod it would be perfect. I wanted to use the same stretch of road, but the GH2 wouldn't last that long.
Anyway here's the test:
@jpbturbo The Patch is Sedna-A and the Card is a San Disk Extreme 45MB/s.
I've been wondering about battery contacts, if they get shaken about. My GH2 has had the Sedna patch for a long time and I see there are plenty of newer versions from Driftwood.
After a run, the GH2 often says "Re-insert SD card" and occasionally "This card is not formatted for this camera"
I have a Sony RX100 which is lighter and might not suffer with the bounce quite so much.
On a wider note this show me the value of testing before a job. I pretty much assumed that everything would work!
The GoPro footage looks best from a stability standpoint, but the IQ is terrible considering what that camera is capable of. Could be the scaling (which I assume was to get similar framing)? Also, no mention of what settings you were using on any of the cams unless I missed it somewhere. If you need max zoom for GoPro, then 1080 60fps in narrow is best option. IQ in this is setting is decent. Otherwise, 2.7k @30fps in medium is usually the best option for highest IQ. Just scale down to 1080 during conversion. And be sure to always shoot in protune for anything high motion or high details like in your shots. In my experience, the Gopro's have trouble resolving detail at the stock low bit rate. This is especially true in aerial applications. We sucessfully cut it with GH2, GH3, 5DIII and FS700 footage with no issues. In the off chance that the soft image isn't related to the scaling up, be sure your GP3+ isn't one of the early production models (pre 11/2013 I think) that had the focus issue.
@filthy it was 1080 50fps Wide Scaled 152% in FCPx. It was running Protune, but I imported directly to FCPx -- My Error! I still have the data on the card - I'll have a look.
@ragnar -- Wish I'd seen your video a month ago! That looks really solid! I reckon your car has very different suspension compared to those I tested with.
There are some other differences on the test. Although its the same roads, the Q3 deals with the pot holes better, also the Q3 was driven slowly compared to the Aygo, which has tight suspension and was driven just under the legal limit for the road.
If I get a chance, I'll test a Canon HF21 and redo the GH2 test with a bit of gaffer!
