| Mode | Format | AR | Resolution | i/p | Frame rate | Bit rate | Bit rate | Notes |
| High Bit Rate | AVCHD | 16:9 | 1920 x 1080 | p | 30 or 25 fps* | 24 Mbps | interlaced encoding (PsF). Firmware v1.1 | |
| 24p Cinema | AVCHD | 16:9 | 1920 x 1080 | p | 24 fps | 24H=24 Mbps | 24L=17 Mbps | |
| Variable Movie Mode | AVCHD | 16:9 | 1920 x 1080 | p | 30,15,12, or 8 fps | 24H=24 Mbps | 24L=17 Mbps | no sound. 24 fps playback |
| MMM AVCHD(1080i) | AVCHD | 16:9 | 1920 x 1080 | i | 30 or 25 fps* | FSH=17 Mbps | FH=13 Mbps | |
| MMM AVCHD(720p) | AVCHD | 16:9 | 1280 x 720 | p | 60 or 50 fps* | SH=17 Mbps | H=13 Mbps | |
| MMM MJPEG, HD | mov | 16:9 | 1280 x 720 | p | 30 fps | |||
| MMM MJPEG, WVGA | mov | 16:9 | 848 x 480 | p | 30 fps | |||
| MMM MJPEG, VGA | mov | 4:3 | 640 x 480 | p | 30 fps | |||
| MMM MJPEG, QVGA | mov | 4:3 | 320 x 240 | p | 30 fps |
*30 / 60 fps on NTSC-country cameras; 25 / 50 fps on PAL-country cameras. Selectable on hacked cameras. (see the GH2 Hack FAQ)
copy /b 00000.MTS + 00001.MTS + 00002.MTS new_file.mts
cat 00000.MTS 00001.MTS 00002.MTS >new_file.mts
